Activity Forums Adobe Premiere Pro Clip renders to red halfway through
  • Clip renders to red halfway through
    Posted by Tom Edwards on December 31, 2012 at 5:51 am
    im putting together some clips of a wedding toast for a friend.
    i have four clips each with the following properties
    (name of clip).mp4
    1920 x 1080
    00;01;48;20, 29.99 fps
    48000 Hz – 32-bit Float – Stereo
    i’ve added Looks to all four clips, yet, the fourth clip, at the :32 mark, renders bright red. the other three render fine
    i’m rendering to flv using Premiere Pro 5.5, utilizing the mercury playback engine.
    i changed the render to mov — it still turns red.
    i deleted the clip. re-imported it.
    cleared all of the fx.
    still does the same thing.
    as it sits in the timeline, it plays back fine.
    this happens on a render.
    i’m stumped.
    any ideas.
    here’s the clip that goes red. (at :32)
    https://www.youtube.com/watch?v=m9lr5OKQPgA&feature=youtu.be
    Tero Ahlfors replied 13 years, 8 months ago 3 Members · 4 Replies
  • Dennis Radeke
    December 31, 2012 at 12:04 pm
    Weird.
    I’d trash prefs, clear cache and then take the one offending clip and render it out as something else without effects. reimport and then try the effect again.
    Good luck.
  • Tom Edwards
    December 31, 2012 at 5:41 pm
    dennis,
    thanks for the reply.
    i cleared the cache and trashed prefs (had no idea how to do either – but google what a concept!)
    neither worked in solving the render issue.
    i opened the offending clip in a new project with no fx at all.
    still renders to red.
    so…
    i opened up my old trusty copy of winavi and attempted to convert the file to several different file formats.
    after trying several that all failed, i was able to convert it to an avi.
    i inserted the avi into the project and tested a render — worked fine.
    the entire project is rendering now.
    my best guess is the file (taken from a new droid phone), must’ve been corrupted somehow. odd though that all clips appeared to be the same and all would play in several different media players.
    while i’m still stumped as to why it rendered that way, thankfully, there’s always a work-around.
    appreciate the input
    tom
  • Dennis Radeke
    December 31, 2012 at 5:53 pm
    Glad it worked out for you. Make sure you explore using Adobe Media Encoder for the future. It is a solid render engine that gives you many more broadcast/video editing friendly codecs.
  • Tero Ahlfors
    January 2, 2013 at 11:04 am
    [tom edwards] “my best guess is the file (taken from a new droid phone)”
    I would suggest not using phone camera footage native. They have a bunch of different issues that can pop up. Dennis already suggested transcoding and that’s what I’d do too.
