Activity Forums VEGAS Pro Clip Quality Variation.
  • Clip Quality Variation.
    Posted by Junya Wright on September 24, 2011 at 8:00 pm
    When I render in Sony Vegas some of my clips look better than others. My goal is to get the video to look good on YouTube in 360p. I record at 29 fps in 1080p! I just want the clips to have the same quality throughout the video.
    Render Settings: Main Concept AVC/AAC
    Profile: Main
    Frame Rate: 14.985 (Half NTSC)
    Field Order: None
    Pixel Aspect Ratio: 1.000
    Number Of Reference Frames: 2 [x] use deblocking
    Variable Bitrate: [x] Two-Pass
    Maximum (bps): 50,000,000
    Average (bps); 50,000,000
    Test Video: https://www.youtube.com/watch?v=b3ukpQuDR5Q&feature=player_embedded
    As you can see the quality start to get lower towards the middle.
    The scene at the football field just looks horrible. I just want the clips to have the same quality throughout the whole video.
    Junya Wright replied 14 years, 11 months ago 3 Members · 10 Replies
  • 10 Replies
  • Stephen Mann
    September 25, 2011 at 4:42 am
    You will have to be more specific.
    Two problems that I see right off – First, one of your talents is wearing a checkerboard pattern shirt. In front of a chain-link-fence. Both will give the encoder fits (technically, Moire patterns), and since you’re using interlaced footage, these patterns are going to create a lot of interlaced artifacts.
    Second, some of your talent are wearing RED shirts. While this is not normally a problem, red in a high-contrast encode will bleed some.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Junya Wright
    September 25, 2011 at 5:14 am
    Thanks, Can you please name the more specific things that you need to know?
  • Stephen Mann
    September 25, 2011 at 7:30 pm
    Be specific as to what you are calling a “quality variation”. It all looks the same to me.
    Steve Mann
    http://www.mmdv.com
  • Matt Crowley
    September 25, 2011 at 8:36 pm
    The shots on the sports field with the red t-shirt look like they were taken in fairly low light and some cloud, so they’re not as crisp as most of the other footage, but a bit blurry and dull/flat. It’s probably similar for the shot on the fenced bridge.
    If possible, you need to re-shoot that take under similar lighting conditions as the rest of the footage. Other than that, it looks good.
  • Junya Wright
    September 25, 2011 at 8:51 pm
    But what if I can’t re-shoot it. Is there any other thing I can do in sony vegas to help?
    I dont get why the field scene looks like that because if you pay attention the first field clip you see (the slow motion extra) is clear but after that it is all blurry.
  • Stephen Mann
    September 26, 2011 at 12:38 am
    Are you’re talking about the girl in the field at :40 to :45 seconds into the video? It looks like the camera autofocus is the problem here.
    Steve Mann
    http://www.mmdv.com
  • Junya Wright
    September 26, 2011 at 4:12 pm
    Thats a young guy with dreads! The field scene at 23 seconds is clear. But the field scenes at 29 seconds and on are horrible looking. How did the quality change like that?
  • Matt Crowley
    September 26, 2011 at 6:31 pm
    [Junya Wright] “The field scene at 23 seconds is clear. But the field scenes at 29 seconds and on are horrible looking.”
    The first shot has relatively little camera motion, so there’s not much motion blur. But look at the guy’s fingers – they are quite blurred.
    The later shots of the same scene have lots of camera motion, and the motion blur is obvious. It’s the same with the single shot with the guy in white tee walking along a path.
    The light was probably too low for the camera, and it’s also having trouble auto-focussing as Stephen pointed out. The sunlit shots are clear and sharp. Maybe you can drop these shots and use some of the other better takes instead if you have enough footage.
  • Stephen Mann
    September 27, 2011 at 4:33 am
    As Matt said, you have a lot of motion in this video and encoders don’t handle motion well. It takes a few frames for the encoder to figure out what is important.
    Most of us can’t afford the encoders that can. Like the Telestream Episode Engine, $4,000.
    Is this one or two-pass encoding?
    Steve Mann
    http://www.mmdv.com
  • Junya Wright
    September 27, 2011 at 4:46 am
    This is two pass vbr encoding..
