Activity › Forums › DaVinci Resolve › Clip playback speed question
  • Clip playback speed question
    Posted by Robert Houllahan on June 28, 2011 at 3:07 am
    Hi
    How do you change the playback speed of clips in Resolve? I saw a short blurb on it in the manual but can not for the life of me figure out how to do it. I want to playback a DPX sequence at 3sec./frame for a monitor calibration using Lightspace.
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
    http://www.cinelab.com
    MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
    Alexander Stepanov replied 15 years, 3 months ago 4 Members · 5 Replies
  • Tim Farrell
    June 28, 2011 at 3:15 am
    Hi Rob,
    In the config page try setting playback frame rate to 0.33333.
    I had a lot of system lockups with 0.33333 though and had better luck with setting it at 0.25, so each patch lasts 4 seconds.
    Let me know how it goes.
    Tim
  • Robert Houllahan
    June 28, 2011 at 4:04 am
    Ok so it is an overall timeline playback and not per clip to make it work, thanks!!
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
  • Dan Moran
    June 28, 2011 at 11:10 am
    Hi Rob,
    If you want to do it per clip go to the conform page, right click on the clip you need to change and click change clip speed. This will allow you to change the FPS of the clip.
    I hope this helps!
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
  • Alexander Stepanov
    June 28, 2011 at 8:02 pm
    Hi Rob,
    [Robert Houllahan] ” I want to playback a DPX sequence at 3sec./frame for a monitor calibration using Lightspace.”
    Which is a result? Was it succeeded to synchronize?
    June 28, 2011 at 10:09 pm
    I mean Lightspace in this mode.
