Clip organization in Bin & Sequence…
Hello,
THE GOAL: I want to select all clips in a bin and add them into a time line trusting that all clips have the play head at the top of each clip so I know that all of the media on the time line reflects ‘ALL’ of the media in the bin.
I know that if I ‘select all’ of the clips in the bin and hit the ‘clear IN/OUT’ key the clips ‘IN/OUT’ points will be removed, but I would like to know how to ‘select all’ clips and set the play head at the TOP of all of the clips. Is this possible?
