Activity › Forums › Adobe Premiere Pro › Clip Note Customization
  • Clip Note Customization
    Posted by Chrisjoyce on March 14, 2006 at 4:53 pm
    Can Clip notes be customized so that when I use them I can get my graphic to show instead of promoting Adobe?
    This was posted previously with no response in another thread. I apologize for the duplicity.
    Chris
    Chrisjoyce replied 20 years, 6 months ago 4 Members · 7 Replies
  • 7 Replies
  • Aanarav Sareen
    March 14, 2006 at 5:15 pm
    Sorry, they cannot be customized.
  • Chrisjoyce
    March 14, 2006 at 7:00 pm
    Thank you for the response Aanarav… cj
  • Steven L. gotz
    March 14, 2006 at 8:05 pm
    Are you sure? I believe there is a PDF that is used for the template. If you have Acrobat (the full version, not just the reader) shouldn’t you be able to modify it? I don’t have Acrobat, so I can’t tell you for sure, but the file is in this directory by default: C:\Program Files\Adobe\Adobe Premiere Pro 2.0\ClipNotes\en_US
    The file name is ClipNotesTemplate.pdf
    Steven
    http://www.stevengotz.com
  • Aanarav Sareen
    March 14, 2006 at 9:09 pm
    Steven,
    Just tried it, but no go. I do have Acrobat 7 Pro, but I can’t seem to change the text.
  • Chrisjoyce
    March 15, 2006 at 4:33 am
    Hi Steve.
    I tried everything. I even created a new pdf that had multimedia in it. Added it to the default folder. But no luck.
    I’ll just keep building web theaters. It just seemed so logical and easy to use. But I need a branded look. Maybe I’ll post on the adobe acrobat forum. There may be something that is undiscovered….. woooooahhhhhh…. cj
  • Tim Kurkoski
    March 16, 2006 at 12:52 am
    Try using Illustrator. It’ll probably give you some warnings, but I tried it now with Illustrator CS2 and it worked fine. Export clip notes from Premiere and it showed the changes I made. Also, the PDF file is read-only, so you have to disable that option in the file properties in Windows Explorer.
  • Chrisjoyce
    March 16, 2006 at 2:26 am
    I don’t have IllustCS2, just CS. I can make changes and pp20 does use the changes but I lose the note capability and it give authorship warnings. Not professional.
    I gotta admit, it was a great thought. I tried psCS2, but failed miserably.
    Thank you for taking the time to get involved!!!!
    Chris
