Activity › Forums › Adobe Premiere Pro › Clip Name Overlay option
  • Clip Name Overlay option
    Posted by Brian Baldwin on May 16, 2013 at 3:33 am
    Does anybody know of a built-in method or plugin that allows for the clip name to be displayed over the footage in the program monitor? A reason to use this would be if you shot a lot of footage over multiple days and wanted to export a “daily” (if you will), so you make a new sequence and drag all of that days footage onto the timeline. Then when you exported the clip names would be overlaid for quick reference.
    I found a workaround in FCP 7 that worked pretty well and came in real handy for my client to scrub through one small h264 with all of that days footage and know exactly what clip to find if they liked a shot.
    Brian Baldwin replied 12 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Brad Baker
    February 28, 2014 at 7:20 pm
    Not sure if you ever found a solution for this but just today I was looking for something similar and discovered that PrPro CC has a “Clip Name” plug-in. That should do the trick.
  • Brian Baldwin
    February 28, 2014 at 8:02 pm
    THIS. CHANGED. MY. LIFE! haha. Thanks so much!
    It seems like such a simple thing to accomplish but this is the first time I’ve seen it built-in to either PP or FCP. I knew I wasn’t the ONLY person who had this request…
    Thanks again!
  • Steve Vallino
    June 11, 2014 at 5:48 pm
    What is the name of the plug in company or where can I find it please?
    Thanks!!
  • Brad Baker
    June 11, 2014 at 6:49 pm
    Check out my post above 🙂
  • Steve Vallino
    June 11, 2014 at 7:34 pm
    Can’t seem to find it on the Adobe CC site, it just lists all the third party companies that make plugins…
  • Brad Baker
    June 12, 2014 at 2:47 pm
    Search for “Clip Name” in the Premiere Pro CC Effects tab.
  • Steve Vallino
    June 12, 2014 at 5:06 pm
    Thanks much! Seems the problem was that I thought the they had me on CC as we just joined the service. Turns out I’m still on CS6 so my mistake. Thanks again for the prompt response and info! Have a great day.
