Clip name display?
Posted by Russell Robertson on September 20, 2005 at 1:39 amI captured a tape which had 52 clips
Bill Mash replied 20 years, 11 months ago 4 Members · 3 Replies -
Mike Kujbida
September 20, 2005 at 2:22 amVegas 5: Options – Prefs – General – Show active take information
Vegas 6: View – Active take information
Gary Kleiner
September 20, 2005 at 2:28 amThere’s no quick way to display the name superimposed on the output.
As Mike points out, you CAN display them on the timeline events. A quick way in Vegas 6 is Ctrl/Shift/i.
Gary
Bill Mash
September 20, 2005 at 5:03 amAnother work-around is view>edit details (Alt+6), events. This will give you a row column list of track names with in and out points as defined on the timeline. This display conforms to a table hence you may click the upper left block to select all results, Ctrl+c to copy and drop it in a spreadsheet for printing and manipulation purposes.
You may then add a event timecode to display the in and out points on the output, which you can then manually match to you (Alt+6) results.
