  • Posted by Luke David on May 8, 2006 at 5:38 pm
    I forgot the check my clip settings before I started logging a tape. I made a bunch of clips and then grabbed them all. The problem; video box was not checked. ugghhhhh! is there a function silimar to ‘clip modify’ in avid or any other way that maybe I can salvage all the clips. thanks for the help and don’t tell me I’m hosed.
    Dean Sensui replied 20 years, 4 months ago 2 Members · 3 Replies
  • Luke David
    May 8, 2006 at 5:51 pm
    solved it! you first have to make it offline and then you can go to clip settings to change the tracks.
  • Luke David
  • Dean Sensui
    May 8, 2006 at 7:36 pm
    Looks like you’re your own best reference. 🙂
    Another way: Get rid of the media you accidently mis-captured from your Capture folder. Make sure your capture settings are properly set. Select the clips you want to replace, hit Apple-C, and check “off” the box that says “use Logged Clip Settings” in the Batch Capture dialog box.
    Dean Sensui — http://www.HawaiiGoesFishing.com
