Activity Forums Apple Final Cut Pro Legacy Clip marker problem
  • Clip marker problem
    Posted by Cassidy Clawson on December 15, 2011 at 1:53 am
    Hello All,
    I have a problem with markers. I’m using them extensively in clips for annotating a documentary.
    I make a marker by pressing m, then m again to load the edit marker pane. I add information to “comments” and click ok.
    Until today, the marker and comment would appear in a box when the clip plays over the marker. Now, suddenly, that feature has stopped. The clip plays over the marker and I get no information. I have checked that “show overlays” is checked.
    How do I fix this? I’m not sure why it has stopped working. Thanks!
    Jerry Hofmann replied 14 years, 9 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    December 15, 2011 at 2:06 pm
    If you place a marker in a clip, it will not show up in the Canvas when that clip is added to a sequence. If you place a marker as a sequence marker it will.
    Markers in clips only show up in the Viewer, and they don’t ever show during playback. Only during a stop over the marker itself.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
