clip length
Posted by John Culleton on May 30, 2007 at 9:25 amwhy does vegas allow me to drag the end of a clip infinitely? i can’t seem to get it to the original length without deleting it off the timeline and re inserting it. must be an option right?
Mike Kujbida replied 19 years, 3 months ago 5 Members · 14 Replies -
John Magee
May 30, 2007 at 1:11 pmWhen you drag out the end of an clip past its “actual” end, you’ll notice a V-shaped notch appears along the top edge of the event. That’s the point where the clip will now begin over from the start, or “loop”. Just don’t drag the event out that far. If you do, you’ll notice a slight hesitation or resistance in the drag before the clip starts looping. Drag it back again and you’ll notice it “snap” into the proper place. I’ve never needed to turn this function off.
Mike Kujbida
May 30, 2007 at 1:16 pm“why does vegas allow me to drag the end of a clip infinitely?”
You may not like it but that’s the way Vegas does it.
Look closely at the clip and, if it’s repeating, you’ll see a tiny notch (looks like a V) somewhere along the top of it. This is the repeatig point. To go back to the original length, drag the end of the clip backwards (or the beginning forward, as the case may be) until the V goes away.
You can also just trim it by using the S (Split) key at the desired point and deleting the unwanted segment.
Gary Kleiner
May 30, 2007 at 1:35 pm[john culleton] “pleeeeez tell me i can turn it off”
Right-click the event and choose Properties. Unchcek ‘loop’.
Then, when you drag it out past the end it stays on the last frame.Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
John Culleton
May 30, 2007 at 1:51 pmoh well… very useful for gfx but one REALLY annoying feature otherwise
Edward Troxel
May 30, 2007 at 2:22 pm -
John Culleton
May 30, 2007 at 3:04 pmi just don’t see the point of it! i’m constantly having to drag the end point back, maybe that’s just me, plus the function only loops one layer, if i have a short graphic on another layer what happens to that?
Edward Troxel
May 30, 2007 at 3:35 pm -
Mike Kujbida
May 30, 2007 at 3:47 pm[john culleton] “why does vegas allow me to drag the end of a clip infinitely?”
There are times (such as text events or stills) that I want to be able to drag the event out for longer than the default time without having to open a box and enter the new time – after I’ve figured out how long that is, of course 🙁
At times like this, I definitely appreciate the way Veags does things. -
John Culleton
May 30, 2007 at 4:13 pmi should explain that Velocity is my Editor, i’m helping a local company who have just lost their editor and i need to get up to speed with Vegas, i kinda see the point of this ‘loop’ feature now, thanks,
