Activity › Forums › Apple Final Cut Pro Legacy › clip length – audio sync issues
  • clip length – audio sync issues
    Posted by Tbarnes on September 13, 2005 at 9:35 pm
    I’m capturing a program that has 4 22 minute segments. After capturing the clips, I’ve been noticing that the audio is in sync in the beginning of the clips and gradually gets out of sync. I’m guessing this is from dropped frames?
    I recently cleared about 120gigs off the capture drive. Will optimizing/defragmenting the capture drive improve my captures?
    If so, what program would you recommend to use to optimize/defragment?
    Any other suggestions to get my clips to stay in sync?
    Thaxter Clavemarlton replied 21 years ago 2 Members · 1 Reply
  • Thaxter Clavemarlton
    September 13, 2005 at 10:08 pm
    “Sync-slippage” can happen during some longer captures.
    Tapes recorded on certain camcorders from Canon have been somewhat more problematic, but it also can happen with other brands of cameras as well.
    To reduce the problem on capture, break your captures into sections no longer than about 10 minutes each.
    You can then “reconstruct” the full tape’s recording (or any longer takes) quickly if you need to.
    Mark (and log) your first clip to End (Out-point) about 10 minutes or less from its In-point.
    Continue to mark (and log) your clips this way throughout the rest of the tape.
    Just make sure the In-points of the subsequent clips are EXACTLY ONE FRAME LATER than the Out-points of the previous clips.
    You can do all this while actually scanning the tape(s) or just by inputting arbitrary TC numbers, logging them… then use Batch Capture to bring in all of your clips.
    Its very easy to then “reconstruct” the shorter clips back to any “continuous” length you want on the timeline by just “clicking” them on in order.
    EVEN FASTER… select ALL successive clips at once in the browser (with the browser column-order set to “Media Start” highlight all clips) and drop them, all at once, on the timeline… they’ll all pop up in continuous order.
