Activity › Forums › Creative Community Conversations › Clip keyword search issue
Posted by Thomas Maher on August 15, 2011 at 12:57 pmHi,
I’m having an issue where FCPX’s clip search is not working. I’ve assigned keywords to many of the clip (see in the smart collections to the left) but when I try to search for keywords within a collection I get no results.
In the attached example I’ve labeled a clip with “hanoi” and “Gabrielle”…. If I do a search for those word in ANY location I get not results (“no clips match the current filter settings”)
can anyone tell me what I’m doing wrong?
best, Thomas
Jerry Hofmann replied 15 years, 1 month ago 3 Members · 9 Replies -
Jerry Hofmann
August 15, 2011 at 6:47 pmOne thing that has to be right is the spelling… are the keywords attached spelled exactly the way the terms you are searching with?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Cathy Murphy
August 15, 2011 at 7:51 pmI believe the search you are currently doing is looking for clips with the name Gabrielle in them vs. clips that have been keyworded with Gabrielle (i.e. you could search for 1904 here to bring up the MVI_1904 clip).
Using the filter window (click on the magnifying glass in the search field) you could create a search that would allow you to make a new collection of clips tagged with either or both the Gabrielle and Hanoi keywords (click on the “+” and check the Gabrielle and Hanoi checkboxes, and set keywords to “include any” or “include all”).
I hope this is what you were looking for?
Thomas Maher
August 15, 2011 at 8:17 pmHi Jerry,
As you can see in my example attachement I have typed in “Gabrielle” the same way it is tagged in the clip below. The same is true for any other clips with keywords (you can see the other keywords I’ve tried searching for in the left keyword collections column).
It will return results if I type in file names, but that is not useful. I can also modify the search where it has check boxes for keywords but that only gives me results for clips tagged with either/or… what I’m trying to get is results for clips that are only both.
any thoughts?
best, Thomas
Jerry Hofmann
August 15, 2011 at 9:00 pmIf you search with the checkbox on next to keywords in the dialog box that opens when you type cmd+f, and the clips are tagged with a keyword they work OK here. If you’re searching for key worded clips, you must have the keywords added to the list (from the plus button in the filter dialog box).
Are you doing that too?
Jerry
Current DVD:
Thomas Maher
August 16, 2011 at 1:39 amThanks Cathy,
Yes, it does seem that the search only produces results based on file names.
Your alternate technique also works well (I hadn’t tried the any/all) The problem is that it takes much more effort to open this box and start checking and unchecking boxes to get results.
Very frustrating that you can’t just do a quick keyword search by typing keywords into the search field.
Any other ideas would be greatly appreciated.
best, Thomas
Thomas Maher
August 16, 2011 at 1:46 am -
Jerry Hofmann
August 16, 2011 at 2:28 amType cmd=f. In the window click on the plus sign in the upper right. Add keywords to the list… then search on the keyword… the clips are displayed in the browser. I just tried this and it works just peachy…
Jerry
Thomas Maher
August 16, 2011 at 2:51 amThanks Jerry,
OK…
I’ve selected all my footage from 2011 to the left…
I hit command-F…
I hit the + on the top right…
I check off all my keywords….
I type in “water” (I have 9 clips tagged with the keyword “water”)…
NADA!!!
You can see in the latest attached image just below the search box it says “no clips match the current filter setting”
Any other ideas on why this might not be working for me?
best, Thomas
