Activity › Forums › Adobe Premiere Pro › Clip Keyframes and Transitions PPRO 2.0
  • Clip Keyframes and Transitions PPRO 2.0
    Posted by Robert on December 10, 2007 at 8:21 pm
    I’m using the motion effect to keyframe hi-res stills.
    I create the keyframes, then add a transition between clips.
    This extends the clip but not the keyframes. I get a dissolve, then the motion starts, then the motion stops, then a dissolve.
    I can quickly move the keyframes to cover the transitions.
    But is there a way to automatically scale the keyframes to match the clip duration?
    In other words, can I scale the keyframe duration to match the clip duration?
    Robert replied 18 years, 9 months ago 2 Members · 2 Replies
  • Jon Barrie
    December 11, 2007 at 3:21 am
    Hi Rob,
    Short answer. No. Longer answer – there is no such function.
    You can cut and paste keyframes however by selecting it , cut, and pasting it where your CTI/Playhead is. Pressing page up or page down will snap you to cut points.
    – Jon
  • Robert
    December 11, 2007 at 2:50 pm
    Jon,
    Thank you for both your direct and in-depth response 😉
    Oh well, that’s what workarounds are for!
    -Robert
