Activity › Forums › Apple Final Cut Pro Legacy › Clip is grayed out and no sound
  • Clip is grayed out and no sound
    Posted by Jack Fox on December 7, 2005 at 6:28 pm
    It’s as if the audio (speaker icon) has been turned off for a single clip. All other clips on the same track play fine. I checked all the mute buttons I could find, and the level is set at zero. The clip plays find when opened up in a viewer, but there is no sound when played in the timeline and canvas. Is there a switch or option that could of turned off the sound for a single audio clip?
    jmf
    Jack Fox replied 20 years, 9 months ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    December 7, 2005 at 6:33 pm
    Did you edit the video AND audio to the timeline?
    Where all the proper tracks selected when you edited the clip to the timeline?
    Check all tracks needed, and edit it in again.
  • Jack Fox
    December 7, 2005 at 6:38 pm
    I did check it over again and found that “Clip Enabled” was not check under the “Modify” menu for the grayed out sound clip.
    jmf
