Activity Forums Apple Final Cut Pro Legacy Clip IN and OUT times missing
  • Clip IN and OUT times missing
    Posted by Dennis Dean on August 24, 2009 at 6:00 pm
    Just starting to digitize using the Log and Capture method and everything seems to be fine EXCEPT once I’ve logged some clips the Batch Capture command gives me an error code saying it can’t find the Time Code. Time Code is, however, coming into the system… but I’ve noticed it’s only appearing under the Media Start and Media End columns for each clip. The In and Out columns show as Not Set. I’m suspect i’ve overlooked something but not sure what.
    Any help appreciated. I’m feeding HDV/DV out of a Sony HVR-Z7U thru the Firewire 400 port into a G5 Dual running 10.4.1
    Bret Williams replied 17 years ago 3 Members · 4 Replies
  • Bouke Vahl
    August 24, 2009 at 6:29 pm
    Are you sure you have enough preroll?
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
  • Dennis Dean
    August 24, 2009 at 7:06 pm
    I should – I’ve tried this several times, usually pulling the clips from the middle of the scene, so there should be plenty of additional scene in front for pre-roll. OR – is pre-roll something that needs to be set somewhere?
    Dennis Dean
    The Dean Group
    -It’s about results-
    http://www.deangroup.com
  • Bouke Vahl
    August 25, 2009 at 12:11 pm
    Then probably the deck is not accurate enough.
    Manually wind to a few seconds before the inpoint and try again.
    Yes, it sucks, yes you should get a HVR 1500 and control it over 422…
    My advice, ingest entire reels and be done with it.
    No babysitting, faster in the end.
    Bouke
  • Bret Williams
    August 25, 2009 at 2:28 pm
    In and out are set in the viewer. Not in log and capture. If you digitize with handles, in and out will be set ad the same in and out from log and capture. But if there\’s no handles, then there\’s no point in having an in and out as it\’s the same. They could go ahead and set them, but it is useful to see if you\’ve viewed a clip and set in/out points or not.
