Activity Forums Apple Final Cut Pro Legacy clip frame rate
  • clip frame rate
    Posted by Alex Harding on August 20, 2006 at 12:08 pm
    is it possible to make FCP play a quicktime which was rendered at 25fps at 24fps? IE something similar to the ‘interpret footage’ options in AE and Premiere
    cheers
    alex
    Alex Harding replied 20 years ago 1 Member · 1 Reply
  • Alex Harding
    August 20, 2006 at 12:10 pm
    PS
    i dont mean retime it to 24 fps, as will happen if you stick it in a 24fps timeline.
    i want it to play every frame in order, and therefore discard the timecode
