Activity Forums Apple Final Cut Pro Legacy Clip format problem
  • Clip format problem
    Posted by Jerry Jones on March 6, 2015 at 6:10 pm
    Am doing a a video for a friend’s funeral TOMORROW! (Am a long-time user of FCP – but this has me stumped.)
    Am working with FCP 7.0.3
    PROBLEM
    1) Have dropped in my clips on timeline
    2) Clips are not all same format
    3) Is there a quick way to make all clips same format?
    – Everything was shot on Panasonic AG90
    – I captured clips using Log & Transfer
    – 3/4 of clips are ok, but the remainder are either too large or too small – and sometimes distorted.
    – I made no changes in clip or sequence settings during any phase of this process.
    – I have been reading this forum (plus other things online) but have still not found a way to fix this.
    – I have looked at both clip & sequence settings and can find no noticeable differences in settings.
    If you have any suggestions on this, I would be very grateful to hear from you ASAP. Funeral is tomorrow.
    Thank you.
    J. David Jones
    V I D E O P R O D U C E R
    Unleashing the Power of Stories
    to Impact the World….
    Follow me on Twitter: jdavid17
    https://www.youtube.com/profile?user=jdavid17
    Nick Meyers replied 11 years, 6 months ago 2 Members · 2 Replies
  • Jerry Jones
    March 6, 2015 at 9:33 pm
    Thanks, Dave. Kind of you.
    – Final out put will be DVD
    – Trying to get everything compatible with the following:
    – HDV 1080 p24
    – Frame: 1440 x 1080
    – Pixel aspect: HD Anamorphic 1080
    But for some reason, a couple of the clips ended up on the timeline larger and slightly distorted. (Again, I brought them in all from same camera and made no changes in settings. So a bit of a mystery.)
    I had already started editing before I realized the problem. If there is anyway to fix this (either via sequence and/or clips).
    J. David Jones
  • Nick Meyers
    March 8, 2015 at 6:14 pm
    or more simple:
    select all the odd looking clips, right click, and REMOVE attributes.
    they should have a green or grey render line above them… do they?
    nick
