Activity › Forums › Apple Final Cut Pro Legacy › Clip duration
  • Posted by Rhys Thorpe on December 3, 2009 at 11:57 am
    Hello.
    I am trying to edit a time lapse sequence in Final Cut Pro. I can change the duration of each clip individually to 12500% but would like to do a batch change otherwise i have about 3000 images to edit individually.
    Any help much appreciated, Rhys.
    Andrew Evans replied 16 years, 10 months ago 4 Members · 3 Replies
  • Shane Ross
    December 3, 2009 at 6:42 pm
    Sorry, gotta do it one by one.
    Editing is time consuming…
    Shane
  • Paul Logan
    December 4, 2009 at 4:46 am
    You could try editing them real time, export uncompressed, import the new movie back into FCP, and change the duration of that file, containing all of your moving images. Or do it in chunks, that might go faster. You are smarter than the machine!
    Paul Logan, Santa Cruz, CA, USA
  • Andrew Evans
    December 4, 2009 at 8:03 am
    is it images or video?
    if it is images you can use QT pro. file/open image sequence/select the images/set frame rate. then you can save it as a .mov. you can choose h.264 and i’m sure some others, i can’t remember off the top of my head.
    hope this helps
    Andrew
