Activity › Forums › Adobe Premiere Pro › clip doesn’t fully import
Posted by Tom Hepburn on November 5, 2008 at 1:56 amI have a 130 Gig AVI file that I’m trying to import into Premier Pro. he total time of the clip is around 22 minutes. However whenever I import it into Premier (or AfterEffects for that matter) is shows the clip at just over a minute.
I can confirm that it’s 22 minutes because, although it can’t play realtime in Window Media Player, I can still see the footage. It also is confirmed in the properties of the file.
Has anyone else had this problem? I’m running Windows XP and CS3.
Thanks in advance,
TomTom Hepburn replied 17 years, 10 months ago 4 Members · 9 Replies -
Jon Barrie
November 5, 2008 at 3:09 amWhat is the avi codec. 22 minutes 138Gig is a massive amount of MB/sec…like 110MB/sec Is it uncompressed?
Jon Barrie
aJBprods
http://www.jonbarrie.net -
Tom Hepburn
November 5, 2008 at 3:41 amYes, it is massive. It’s uncompressed. I did a test with a 4gig sample and it worked OK. Obviously, no where near as big as this. Do you think that is why only a portion is coming in Jon?
Eddie Lotter
November 5, 2008 at 2:41 pmBe sure that it is a type 2 AVI. Type 1 AVI files have a size limit.
Cheers
Eddie -
Tom Hepburn
November 5, 2008 at 3:16 pmHi Eddie,
I never knew there were two types…errggg
How can I get that information? Is it embedded in the file somewhere, properties? Also, if it is in fact type 1, is there a work around. It’s tough to convert a file if you can’t even see it.
Thanks in advance,
Tom -
Eddie Lotter
November 5, 2008 at 4:42 pmYou can use a utility like GSpot to interrogate AVI files to determine their properties.
To covert, see a recommendation in AVI in the PremiereProPedia.
Cheers
Eddie -
Andrew Longhurst
November 5, 2008 at 6:50 pmDepending on what quality you need to edit with, I’d reccomend converting the original file to another format before importing – MPEG 2 would work for many projects or perhaps H264?
There are a lot of apps out there for this kind of conversion from the free quick and dirty to the very sophisticated and expensive.
I can recommend any number depending on your final usage rquirements and budget.
Kind regards
Andrew
Andrew Longhurst
The Art of MixIs it pixels or pixies that I’m having trouble with?
Eddie Lotter
November 5, 2008 at 7:23 pmUsing lossy compression on a clip before editing it is a sure way to lose quality. Not a recommended workflow. Stick with uncompressed or use a lossless compression scheme.
Cheers
Eddie -
Tom Hepburn
November 5, 2008 at 7:53 pmThanks for the help so far all,
Eddy Yes. It is uncompressed to retain as much quality as possible.
I have some things I’m going to check tonight:
https://support.microsoft.com/kb/927544Tom
Tom Hepburn
November 6, 2008 at 2:40 amOK, well, not great news for me. It is a type 2 avi after all.
I can’t save it in any other format because I can open it in any software other than Windows Media Player. One other possibility is that I only have 1.5 gigs of RAM. Tomorrow I’m order more.
Thanks for the responses and if there are any other idea let me know. I’ll post the results when I get more ram.
Tom
