Activity Forums Boris FX Clip disappers in Boris Red UI
  • Clip disappers in Boris Red UI
    Posted by Kevin Lankford on November 8, 2011 at 12:41 am
    A friend of mine and I just built a new computer (detailed below) and I am so frustrated in that it is no faster than my duo core laptop. I obviously don’t have something set up correctly but for the life of me I cannot figure out what it is. In the project I have a standard definition VTS mpeg file on the timeline in Vegas Pro 11 latest build. I open up the Boris Red UI within a 12-second clip and after playing through the clip once within the Boris UI, the clip usually disappears and a green Boris Red V1 flash screen appears. When I’ve been able to apply a simple fly-in text with motion blur off (“Bad Storm!”) at keyframe one second and a 3-D shatter effect at keyframe 3 seconds, I’m only able to play it through if I set resolution to quarter and quality to low. Then when I hit apply and exit Boris, Vegas might play five frames of the entire 12 second clip. Selectively pre-rendering the clip takes almost 15 min. and playback is still so bad that you can’t even see the text fly in. It’s there and then there’s a couple of frames of shatter and then it’s gone. I have to set the preview to DraftTemp>Sony>Vegas Pro>11 path. I have also tried to uninstall and reinstall on the D drive but I still get the temp files going to that path.
    If anyone has any good ideas on what I should do I would greatly appreciate it. Thanks.
    Kevin
    System Specs:
    Asus P8Z68-V PRO mobo
    Intel i7 2600k OC 4.5GHZ
    CM Hyper 212+ CPU Cooler
    Ripjaws X Series 16GB DDR3 1866
    Asus Nvidia Geforce GTX 570 1280MB 320-BIT GDDR5
    OCZ SSD 90GB (boot drive – W7 Professional 64-BIT)
    2 x WD 1.5TB HDs
    Asus Blu-Ray Writer/Player
    DVD/CD Writer/Player w/ Lightscribe
    Rosewell 75-in-1 Card Reader
    CM 750W PSU
    CM Haf X Case (Blue Edition – Really Cool!)
    Kevin Lankford replied 14 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
