Activity Forums Apple Final Cut Pro Legacy clip disapears when above clips rendered
  • clip disapears when above clips rendered
    Posted by Michael Garske on February 10, 2008 at 4:14 am
    This is a weird one. Sounds to me like a glitch in the program but maybe someone can help.
    I have 3 tracks. The base track has a clip with no motion or effects applied. the 2nd track has a clip with basic motion that needs no rendering. The 3rd track has a clip with an effect that needs to be rendered.
    When I render the third clip the 2nd clip’s image no longer appears (for the duration of the above rendered clip), only the wireframe appears. However the clip on the base track is still viewable. If the section isn’t rendered than all 3 are viewable.
    I’m using 6.0. Has any encountered anything like this before?
    Mike
    Michael Garske replied 18 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
