Activity Forums Adobe Premiere Pro Clip Description – Persistence of Metadata
  • Clip Description – Persistence of Metadata
    Posted by Stephen Lovett on March 20, 2012 at 8:05 am
    I’ve found what is to me rather odd behavior, but let me start with what I’m trying to accomplish.
    I want an assistant editor to able to enter information into the Description field for a clip, without having to import the clip into a project.
    We primarily work with RED footage so I’ll use that in my example.
    In Premier Pro 5.52 in the Media Browser, if I double click a clip, it opens without adding the clip to the project and allows content review, so far great.
    If I select the Metadata tab for that clip and enter a comment in the description field it also works as I expect. Namely if I move on to another clip an do the same and then later open the first clip I annotated, the comment I entered in that first clip persists and is visible when viewed from within the Media Browser.
    However if I subsequently import that clip into a project, the metadata in no longer present when clip data is viewed in the Project pane…
    This has to be a common task, so I’d love some guidance on how you folks are managing this.
    Best,
    Steve
    Alex Udell replied 14 years, 6 months ago 2 Members · 5 Replies
  • Alex Udell
    March 20, 2012 at 1:36 pm
    Steve…
    I’m wondering if the “Description” you are entering might be mapped to another metadata field?
    Check out this thread from a few months back:
    https://forums.creativecow.net/readpost/3/918834
  • Alex Udell
    March 20, 2012 at 1:43 pm
  • Stephen Lovett
    March 21, 2012 at 2:08 am
    Hi Alex,
    Thank you for the pointers.
    Unfortunately the information enclosed didn’t lead to a resolution for a couple of reasons.
    I checked the setting and Subject was already enabled within the meta data menu/tab.
    Plus these folks are talking about working in Bridge which doesn’t support browsing R3D data, and is being deprecated in the next version as far as I know.
    It sounds like Prelude coming in CS 6 is what I’m looking for, I guess I can load the clips into a project…
    Steve
  • Alex Udell
    March 21, 2012 at 1:08 pm
    So those changes didn’t show up in the dublin core in PPro?
    Alex
  • Alex Udell
    March 21, 2012 at 1:12 pm
    thanks for the tip about Prelude. very interesting!!
    Alex Udell
    Editing, Motion Graphics, and Visual FX
