Activity Forums Avid Media Composer clip comments missing in bins
  • clip comments missing in bins
    Posted by Helen Browning on July 7, 2014 at 2:07 pm
    I’m logging footage in media composer 8 and regularly saving my work. When I open up the project the next day a lot of the comments are gone. I can’t determine any pattern as to why some bins retain all the comments and others lose half or all the comments…
    Any help much appreciated.
    Craig Hirshberg replied 11 years, 6 months ago 4 Members · 9 Replies
  • 9 Replies
  • Michael Phillips
    July 7, 2014 at 3:47 pm
    Are there duplicate clips around, or are these always the one single master?
    Michael
  • Helen Browning
    July 8, 2014 at 1:23 am
    Hi Michael, they are the single masters..used in sequences but not duplicated.
  • Helen Browning
    July 8, 2014 at 10:38 am
    Also, the ‘save bin’ option is not available, only ‘save bin copy’ which I tried but it won’t let me while the bin is open…
  • Michael Phillips
    July 8, 2014 at 1:41 pm
    Are you in shared storage using shared project and bins? If not, does the drive have full read/write permissions for where the project/bin is being stored when working?
    Michael
  • Helen Browning
    July 8, 2014 at 2:08 pm
    Hi Michael, many thanks for responding. I’m saving the project files to my iMac (not shared) and the media is on an external drive. I’ve done a verify then repair permissions on my drive in disk utility but it didn’t help unfortunately.
    What is working is putting a sequence in each bin (just a new sequence)…then the ‘Save Bin’ option becomes available and nothing seems to be disappearing. This is solving the problem for now but I have no idea why….do you know? thanks again, Helen
  • Michael Phillips
    July 9, 2014 at 12:09 am
    Aside from permissions, did you “get info” on the drive and check Sharing & Permissions in that window?
    Maybe move the project temporarily to the external drive and open it form there and see if you can save bins. Or try a “save as” and save it to the external drive and if that works.
    Michael
  • Vicente Perez
    November 20, 2014 at 8:17 pm
    I am having the same problem here. I have checked the permissions on my external drive, and it is READ/WRITE for all users (for the entire drive and every folder within).
    There are two funny things:
    -Sometimes the changes stick, but I could not find a pattern to it.
    -If I leave the bins open with my notes and shut down Avid, when I launch Avid again, the bins are still open, but the notes are gone.
    Any thoughts?
  • Vicente Perez
    November 20, 2014 at 8:30 pm
    And one more funny thing. As Helen mentioned, SAVE BIN is greyed out. But if I chose SAVE BIN COPY AS, the comments get saved (probably this is the reason why sometimes the changes did stick, as I mentioned earlier) for the original bin.
  • Craig Hirshberg
    February 13, 2015 at 2:31 pm
    I’m having the exact same problem as well. Recently upgraded system to a new iMac i7, Yosemite 10.10.1, Avid MC 8.3.0.
    First time it happened was after a crash, but I had been saving religiously as I always do. Next time it happened was after a save and exit of the program. It is very random. Only some of the comments in a bin are lost, not the entire bin. And it doesn’t even have to be the bin that is currently open (I keep mine in tabs).
    Very frustrating, I hope Avid can fix this quickly.
    Craig Hirshberg
    Rock Creek productions, Inc.
    http://www.rock-creek.com
