Activity › Forums › Sony Cameras › Clip Browser Error Message “Umid not found”
  • Clip Browser Error Message “Umid not found”
    Posted by Nadia Musallam on April 20, 2009 at 8:36 pm
    I need some serious help! I can tell you exactly what happened. I was in a major rush and forgot to stop recording before I switched out the battery (I know, I know, but it was a crucial moment when I realized the battery was going to die in an even more crucial moment). At the time, my EX-1 told me I needed to restore the media to continue using the card. I did that and it brought everything up just fine. I can watch the clip in question on the camera’s playback, and when I bring it into clip browser, I can watch it just fine there too.
    The problem is that I cannot convert it to mxf (which I need for Sony Vegas 8c). The message I get is “Condition Failure-Source Umid Not Found”. I have copied the original BPAV folder and stored it. I can see the file in there too, but it is split in two. I have tried to bring the file in clip browser straight through the BPAV folder and it still gives me the error message.
    Funny though, when I see the clips in clip browser, my clip comes up as “0266” and in BPAV it comes up as “0266_1” and the second folder is “0266_2”.
    Any suggestions on how I can grab this file as a working mxf would be greatly appreciated!!
    Craig Seeman replied 17 years, 5 months ago 2 Members · 3 Replies
  • Craig Seeman
    April 20, 2009 at 9:26 pm
    umid is the unique file identifier. Sounds like something went awry with the metadata on that clip.
    Try pulling out the .mp4 of the BPAV and use ClipBrowser 2.5 File/Import (which imports orphaned mp4 files). That should create a new BPAV for it. See if you can create MXF for NLEs if imported into ClipBrowser that way.
  • Nadia Musallam
    April 20, 2009 at 10:04 pm
    Thank you so much Craig! I totally worked!! Thank you thank you thank you!!!
  • Craig Seeman
    April 21, 2009 at 2:23 am
    You’re welcome of course!
    Given your description I had a hunch it was just the metadata that was damage and the file itself was still good.
