Activity › Forums › Sony Cameras › Clip Browser 2.00.01
Posted by Bea Kay on March 18, 2009 at 7:47 pmGentlefolk:
Clip Browser 2.00.01 for Mac–downloaded from the American Sony site–does not work (it installs the camera icon in the dock, but nothing opens) and will not uninstall from my intel MacBook. Finder can’t find it; only the 2.00 version from the UK site sees it, reporting an earlier version that prevents it from installing. This has happened in two different Macintosh computers.Any suggestions on how to fully uninstall Clip Browser 2.00.01 from my MacBook?
Thanks for your time–BK
Chris Linke replied 17 years, 5 months ago 4 Members · 7 Replies -
Craig Seeman
March 18, 2009 at 8:11 pmMost recent version of ClipBrowser is 2.5
https://servicesplus.us.sony.biz/sony-software-model-XDZP1.aspx
Chris Linke
March 18, 2009 at 9:21 pmYou will need to perform minor surgery on the installer. If it’s not already there, copy the “Clip Browser” installer package onto your hard drive.
– On the file now on your hard drive, control-click and choose “Show Package Contents”. A window will open showing you a folder called “Contents”.
– Open the “Contents” folder. You will find a file called “Info.plist”. Open this file in TextEdit.
– You’ll see a bunch of key entries. A little ways down the list is an entry marked <key>IFPkgFlagAllowBackRev</key>. On the next line, replace the word “false” with “true” (no quotes).
– Save the file, then close the package window.Now when you run the installer, it will tell you that there’s a newer version, but this time it will allow you to install.
Chris Linke
PRC Digital Media
http://www.prcdigital.com -
Sam Campbell
April 21, 2009 at 10:12 pmHi,
I am also having the same issue.I have tried the method you suggest, but when i try to save the changes made in the text edit it will not save.
“the document “info.plist” could not be saved”
any idea on what i am doing wrong??
at his stage any help is really appreciated
lost & confusedSam
Chris Linke
April 22, 2009 at 12:39 amDid you copy the installer onto your hard drive? I don’t know if it will work if your trying to change a file residing on a disk image.
If that’s not the problem, do a “Get Info” on the plist file and check the permissions. Make sure you’re allowed to read and write.
Chris Linke
PRC Digital Media
Sam Campbell
April 22, 2009 at 1:16 amThanks for the response.
It is on the hard drive.Get info on the plist file tells me it is read only – is it possible for me to change this?
many thanks
Sam -
Chris Linke
April 22, 2009 at 5:03 pmUnder the “Read only” box, click on the triangle next to details to expand the area. Click on the little lock icon next to the “Owner” box and then you can change the owner to yourself and give yourself read/write permission. In doing this, you may be prompted for your password. Enter it.
After you’ve changed and saved the plist file, change the permissions back to the way they were. That should take care of everything.
Chris Linke
PRC Digital Media
