Activity › Forums › JVC Cameras › Clip broken into 50 – 1 to 5 second pieces
  • Clip broken into 50 – 1 to 5 second pieces
    Posted by Suzanne Lucas on October 24, 2010 at 3:29 am
    I have had clips break into 1 to 5 second pieces when transfered into my NLE (Vegas 8) from my JVC HD100Ua. Everything plays back fine on the camera. It has happened a couple of times and I can not find a commen event that could be causing it, it is so random. Has anyone else had this problem and can I fix it? Help
    “If you ask me what I came into this world to do I will tell you, I came to live out loud.”
    Will Granzier replied 15 years, 11 months ago 2 Members · 1 Reply
  • Will Granzier
    October 25, 2010 at 9:24 pm
    Hi Suzanne
    Well i dont know much about the Vegas package, but I had this on FCP.
    What I did to sort the problem on Apple was to capture as a non device control unit.. IE the software writes its own time code as it goes along. Can you do that on Vegas ? SOunds like your cams time code is going haywire at times. I had a it a few times when I was on Ver 5.1 but since Ver 6 its kinda gone
    ??? Hope this helps
    Regards
    William
