Activity › Forums › Apple Final Cut Pro Legacy › Client Wants Multiple Frames of people saying lines in sync.
Posted by Ned Miller on December 27, 2012 at 11:26 pmI assume that some of you have been requested to do this before so I’d appreciate any advice. A client has employees all over the globe and wants them to do a Skype, or I suppose it can just be a captured video, saying something that is THE EXACT SAME LINE as everyone else, then wants them to be in their own box (ala Brady Bunch) but may want up to 40 frames. Almost like a mosaic.
I will instruct them to look at the camera for 5 seconds before and after delivering their line, add a smile at the end. I will send out instructions as to framing, background,etc and may send out a 10 second example of me doing it so they know the pacing. I believe the line is just five words.
My question is: If the client wants a LOT of people simultaneously on screen do you know of any templates? Any advice? Is there any appreciable difference between having them do a Skype session vs just doing a video and sending it? I realize with Skype we can “direct” them a bit.
Many thanks,
Ned
Ned Miller
Chicago Videographer
http://www.nedmiller.com
www,bizvideo.comKevin Camin replied 13 years, 8 months ago 8 Members · 9 Replies -
Mark Suszko
December 28, 2012 at 3:19 amCan’t help with the templates. I foresee lighting and audio problems. I do urge you to have them all perform to a pre-made sample audio track, so they all have close to the same rhythm and pace. Each should do more than just the short line, they should have some “handles” on either side of their take.
As to lighting: the Skype users will be close to their monitors and probably NOT looking directly into the webcam. You will likely have backlighting probe, screen reflections on glasses, funky color temps on faces due to screen colors, and weird lighting due to most light coming off the screen. For audio, those wearing a headset will sound right, the rest will be far off-mic.
The real camera users will have better resolution, but lord knows what they will have for audio, likely the on-camera shotgun, and a roulette wheel of lighting and framing choices. I don’t envy the post tasks you have. It sounds like it will look cool, but behind the scenes, this is a bear to put together with good sound and color grading, your template is the least of the problems, I think.
David Eaks
December 28, 2012 at 11:14 amThere’s also the issue of trying to work with 40 tracks of video stacked up. You could build it in several sections with just a few of the clips each, then export each section and bring the new files back in to put it all together.
Steve Eisen
December 28, 2012 at 2:50 pmHappy Holidays Ned. There are no templates that I know of. Depending on how many faces you want to see on the screen at a time, resize your clip and place on video layer. Copy and paste attributes then move the clip over. Repeat till you fill your screen.
There is a video tutorial on how to do this.
https://www.youtube.com/watch?v=sIkOajsWar4Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users GroupSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Victor Perez
December 28, 2012 at 5:50 pmFor the audio, does it matter that the voice is actual sound from the 40 people on screen. I would record myself and some others in the office saying the line several times to get good timing and audio. If possible have a group say the line together. Does not have to be 40 people in the group, maybe 5 or 10. After recording multiply the track, offset by a few frames, filter creatively and voila, 40ish people. I believe the group method might be simpler because you can hear the words together live as well as having the group adjust the tempo according to your needs.
Good Luck,
Victor
editvictor.com
http://www.hbhm.tv
http://www.itvisus.com -
Ned Miller
December 28, 2012 at 6:01 pmThanks Victor, that’s what I plan to do. And thank you all for your advice. Much appreciated.
NedNed Miller
www,bizvideo.com -
Jeff Meyer
December 28, 2012 at 6:59 pmDave makes a very good point here with “a few good takes.” I would ask for at least three. Also, be sure to send a sample audio file. New Yorkers speak faster than mid-westerners. Hopefully a sample clip will get everyone on a similar tempo.
Nick Meyers
December 28, 2012 at 11:08 pmgood idea about the pre-record.
if you do want to chase good sync from the on-scren performs,
i would suggest making up a small LOOP.
it has the LINE, then a gap, slightly longer than the line. the actor repeats the line here,
then the LINE again, than a gap, then the LINE again and a gap.so as the look plays, the actor hears , then repeats the line 3 times or however many times you have the line in the loop.
i have done this, re-recording dialogue on naturalistic locations.
as your people are not repeating a line they had said themselves, i would make more then 3 passes in the loop.nick
Kevin Camin
December 29, 2012 at 7:24 amThis is definitely more in the realm of motion design and fx work than editing. This would be so much easier to do in After Effects in terms of getting 40 squares on screen. You could do really cool things like have a 3D camera swooping around the squares at a dynamic angle and then pull back to reveal all the squares at once for a climactic finish.
I also think you are going to have to do an extraordinary amount of work to make these people look good. 99% of people don’t know what lighting looks good or how to frame themselves properly. They can have a reference image right next to them, but I bet most will not be able to replicate it well. They are busy, probably don’t want to do this, and are not visually literate people. My point is that your creative director or whoever should be firmly aware this could very well turn into a nightmare, and it will not instantly look very good without a lot of the budget going into repairative work and some of the videos might be unusable.
I work as a motion designer and do some editing. I’ve been to a few rodeos and these user generated videos are always a hard drive full of s#it. People are trying to save a buck by not hiring professionals to shoot testimonals or sound bites, but then spend an inordinate amount of money in post just to make the footage digestible. It is a mistake in my opinion to work this way. They just need to hire a camera guy or gal to go down to the company and replicate the look of web cam footage, but provide you with a clean and clear, well exposed video.
Good luck. I’m not really complaining because I get more work or hours with user generated footage, but I fully recognize it’s usually not the best work practice.
Best regards,
Kevin Camin
