Activity Forums Apple Final Cut Pro Legacy Client wants AVI file
  • Client wants AVI file
    Posted by Hal Beery on July 27, 2006 at 8:56 pm
    My edit station is crunching a dvd project so can’t get to it, meanwhile client sent urgent request to have same an AVI file format for his website. What’s the easiest, quickest, cheapest way to do that? Are there other file types usable on web sites?
    tnx in advance for the advice,
    HalB
    Sebas replied 20 years, 1 month ago 4 Members · 8 Replies
  • 8 Replies
  • Jerry Hofmann
    July 27, 2006 at 9:00 pm
    There’s lots of file types usable on a web site, but there may be some limitation to what the web master there can work with…
    AVI’s can be exported directly from FCP though. Look in File/Export/Using QuickTime Conversion, and in the popup menu there, select AVI for the export.
    Jerry
  • David Bogie
    July 27, 2006 at 9:52 pm
    You cna waste a lot of time doing this so make a quick phone call and ask what codec, what bitrate, what file size, what frame size. Try to get answers to at least two of those.
    If you’re lucky, the response will not be, “Huh?”
    bogiesan
  • Hal Beery
    July 27, 2006 at 11:59 pm
    yer hurtin me… thanks for the lower abdominal incision!!!
  • Hal Beery
    July 28, 2006 at 12:02 am
    Merci’
  • Jerry Hofmann
    July 29, 2006 at 2:19 am
    I’d send them what they asked for. Chances are they are going to do their own compression for the web or whatever…
    Jerry
  • Hal Beery
    July 30, 2006 at 7:58 pm
    Ooooops, I said OK, because your instructions were clear and I’ve done similar QTC a zillion times……….but never AVI…. I have fcp 4.5 and it aint on my options list! Am I blind or is just not in 4.5?
  • Jerry Hofmann
    July 30, 2006 at 11:11 pm
    Gee I thought it was… look in FCP 4.5’s Help and search for AVI…
    Jerry
  • Sebas
    July 31, 2006 at 7:25 am
    if it’s not in fcp then you can do it in quicktime. file->export
