Activity Forums Apple Final Cut Pro Legacy client want Mpeg2 50i converted to 25i
  • client want Mpeg2 50i converted to 25i
    Posted by Max Christensen on November 10, 2009 at 12:13 am
    Great! I recived yet another dysfunctional mpeg2! ;-9 (Hate that format)
    Client wants me to convert it from 50i to 25i.. That’s all the info i get! I try to open it with mpeg streamclip.. Nothing. I try to open it in FCP.. wont read. I try to pull it into quicktime.. blank!
    Only compresor and episode can handle it.
    Now my question is.. what do i change to make 50i into 25i??
    Kissis and mpeg2-huggies.
    Max
    Michael Gissing replied 16 years, 10 months ago 2 Members · 4 Replies
  • Michael Gissing
    November 10, 2009 at 12:20 am
    I suspect your client doesn’t use terminology correctly. 50i means 25 fps with interlaced fields. 25i means 12.5 fps with interlaced fields.
    I suspect your client doesn’t actually want to halve the frame rate.
  • Max Christensen
    November 10, 2009 at 12:39 am
    Then i can only woooonder wtf he’s talking about?! :p
    We can both agree that 12.5 frames is impossible to look at for broadcast. I then wonder what client meens,
    or wants?
  • Max Christensen
    November 10, 2009 at 12:44 am
    Maby they meen a 50i converted to a 25p? is that likely.
  • Michael Gissing
    November 10, 2009 at 1:50 am
    If it is an mpeg2 for broadcast it should be 50i.
    I can’t guess what your client wants. You will have to ask them.
