Activity › Forums › Apple Final Cut Pro › Client requesting ProRes 422 files a 25Mbps bite rate
  • Joe Marler
    December 10, 2019 at 9:18 pm
    [Greg Ball] “How would I check the bitrate of an exported video file? Is there a way to do that on a Mac?”
    I suggest you get Invisor. It is inexpensive and allows spreadsheet-like side-by-side viewing of video file metadata. In Finder you can right-click the file or files, then pick Services>Analyze with Invisor. You can also drag/drop additional files from Finder to the Invisor comparison window.
    https://apps.apple.com/us/app/invisor-media-file-inspector/id442947586?mt=12
    If you don’t mind a command line utility, ExifTool gives the most detailed metadata info: https://exiftool.org
Page 2 of 2
