Activity › Forums › Panasonic Cameras › Client monitor/HD thru SD firewire?
  • Client monitor/HD thru SD firewire?
    Posted by Richard Robbins on September 17, 2008 at 9:55 pm
    I suppose that this has been covered ad nauseum. I’m not sure how to search for this. I’m able to import and edit P2 720pn material on FCP/Mac G5 2×3 GHz Dual-Core Intel Xeon yadda yadda…
    Previously, I have been importing DVCPRO50 thru Firewire and monitoring FCP through the Firewire connection. I also have been changing the playback settings in Audio/Video Settings to allow playback through a DVD recorder which worked great for the client monitor.
    This apparently doesn’t work with DVCPROHD 720pn. I can edit just fine on my Cinema displays, but the Firewire connection will only display a still frame. The audio passes fine but not the video. Any thoughts?
    Rich
    John Fishback
    replied 18 years ago
    3 Members · 2 Replies
  • Michael Sacci
    September 18, 2008 at 7:04 am
    You need to invest in a video card from AJA, Blackmagic or Matrox to go to an external monitor.
    The other option is a 2nd computer monitor set to Digital Cinema Desktop Preview in FCP as a fall back.
  • John Fishback
    September 18, 2008 at 4:07 pm
    Another option is using the MXO.
    https://www.matrox.com/video/en/products/mxo/
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 2600 XT
    ATTO ExpressSAS R30F RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
