Activity › Forums › Apple Final Cut Pro Legacy › CLIENT CAN’T PLAY QT/HD on PC
Posted by Dunwoody Lampton on January 9, 2015 at 7:44 pmI have a client who wanted interviews shot/edited to play
on-demand for their website.
They requested High Definition end format.I used Sony HDV camera recording to MiniDV tape
and editing with Final Cut Express HD 3.5.1.Been editing at home and sending approval links to
the client using .wmv files since they upload/download
quicker than the end format – full res HD files.After three early versions the client finally approved
the final version so I converted it to Quicktime 1080i HDV,
which are of course very large files.The client is trying to view the final QT/HD version on
PCs that don’t have Quicktime for Windows installed.
They’ve already approved the final version in .wmv format
but are curious/want to see the “real” final HD files as
they will look/play on the website,
but can’t because – again – they don’t have QT installed
on their PCs or don’t own an Apple device.Is there any way around this or do they simply have to
install QT/Windows or buy/borrow an Apple device?Dunwoody Lampton replied 11 years, 8 months ago 4 Members · 13 Replies -
Mark Suszko
January 9, 2015 at 9:38 pmYou might try other media players like VLC or MPEG Streamclip, both of which are free. But they may still require adding the QT player component.
John Rofrano
January 9, 2015 at 10:37 pm[Dunwoody Lampton] “They’ve already approved the final version in .wmv format but are curious/want to see the “real” final HD files as they will look/play on the website, but can’t because – again – they don’t have QT installed on their PCs or don’t own an Apple device.”
If you are delivering for the web, you should deliver in a format that will play on every device. A ubiquitous web format is MPEG4 AVC/H.264 files. You can probably use Apple Compressor to create these from your HDV QuickTime files.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Dunwoody Lampton
January 9, 2015 at 10:57 pmJR – first, thanks for quick response.
The client insisted on HD acquisition AND HD end format. Not much I could do to talk them out of it.
I’m working with a PowerMac G5/Dual and F.C.E. HD 3.5.1.
The few times I’ve converted to .mp4 files they always carry a Quicktime file package, so these still won’t open on PCs without QT installed. Also, will the conversion to .mp4 maintain High Definition acquisition are will these by Standard Definition/.mp4 files I would be producing?
Also, once these final versions are uploaded to the client’s website, any PC or Mac will be able to view/play.
Dunwoody Lampton
January 9, 2015 at 10:59 pmYes, I have used M-peg Streamclip and it required QT component (for $20). So this will still produce a file wrapped in a QT package.
Walter Soyka
January 10, 2015 at 12:14 amApple’s HDV codec isn’t available for QuickTime for Windows; it’s only available on the Mac.
While web distribution will probably be H.264, you might consider offering them a ProRes master if they insist. ProRes decode is cross-platform.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Dunwoody Lampton
January 10, 2015 at 12:40 amW.S. – thanks for response. If ProRes is compatible with ancient PowerMac G5 and old F.C.E. HD 3.5.1, then awesome. If not, then it will be awhile until I can afford hardware and software upgrades.
John Rofrano
January 10, 2015 at 1:55 pm[Dunwoody Lampton] “The client insisted on HD acquisition AND HD end format. Not much I could do to talk them out of it.”
There is no need to talk them out of it. You should deliver HD 1920×1080-30p MPEG4 AVC/H.264 media to them.
[Dunwoody Lampton] “The few times I’ve converted to .mp4 files they always carry a Quicktime file package, so these still won’t open on PCs without QT installed.”
The .mp4 file is a subset of .mov because the MPEG4 container is a subset of the QuickTime container. I have rendered .mp4 files on my PC and renamed them to .mov and given them to Mac clients that demanded QuickTime files and they have accepted them and are none the wiser because one is a subset of the other. All modern PC’s (Vista, Windows 7, Windows 8) can play .mp4 files with Windows Media Player with no additional software. Windows XP might need the latest version of Windows Media Player because the one that ships with XP is ancient. You do not need QuickTime to play .mp4 files on a PC.
[Dunwoody Lampton] “Also, will the conversion to .mp4 maintain High Definition acquisition are will these by Standard Definition/.mp4 files I would be producing?”
They will be High Definition. AVC/H.264 is what Blu-ray disc are made of. It can be higher quality than the original HDV you shot. AVC/H.264 @ 16Mbps is equal in quality to HDV @ 25Mbps.
[Dunwoody Lampton] “Also, once these final versions are uploaded to the client’s website, any PC or Mac will be able to view/play.”
They will play on Windows, Linux, and Mac computers. All modern browsers support the playing of MPEG4 files. It’s the only format that is natively cross platform.
~jr
John Rofrano
January 10, 2015 at 1:58 pm[Walter Soyka] “you might consider offering them a ProRes master if they insist. ProRes decode is cross-platform.”
Yea, but that doesn’t solve his problem of not requiring QuickTime on Windows. You can’t play a ProRes file on Windows without installing QuickTime first. It sounds like the client want’s a finished internet ready file. That would be MPEG4 AVC/H.264 (.mp4).
~jr
John Rofrano
January 10, 2015 at 2:19 pm[Dunwoody Lampton] “If ProRes is compatible with ancient PowerMac G5 and old F.C.E. HD 3.5.1, then awesome. If not, then it will be awhile until I can afford hardware and software upgrades.”
With all due respect… what is your business plan for upgrading your 11 year old computer? How long is “awhile”? If your clients are requesting that you deliver modern internet formats, you need a computer that can generate modern internet formats.
I ask only to help because not too long ago I picked up a 2008 Mac Pro 2.8 Ghz 8-Core. 16GB memory, Radeon HD 5870 for $740 USD on eBay and it’s running Yosemite and Final Cut Pro X quite nicely. You might be able to afford an upgrade that gets you back in the game if you buy “less used” hardware than what you have to get you onto the Intel Mac platform.
~jr
Walter Soyka
January 10, 2015 at 7:23 pm[John Rofrano] “Yea, but that doesn’t solve his problem of not requiring QuickTime on Windows. You can’t play a ProRes file on Windows without installing QuickTime first. It sounds like the client want’s a finished internet ready file. That would be MPEG4 AVC/H.264 (.mp4).”
Roger that — I thought he was assuming that they must not have QuickTime because they couldn’t play the Apple HDV QuickTime files. Those files would not play on a Windows system with QuickTIme, either. I should have read the OP more closely, because he clearly said that they do not have QuickTime installed.
Walter Soyka
