  • Posted by Brett Sneed on June 22, 2006 at 10:00 pm
    I also posted this in the Flash forum… but haven’t gotten a response, and the answer I am looking for might be more code based than somethng in Flash… anyway, the questionn is:
    In the newest IE, it now requires the viewer to “Click to activate and use this control” on a flash .swf file in a webpage (ones with clickable objects in them). However, I’ve seen it where you don’t have to click to make it work… what’s the secret? An example can be found at https://www.opuscorp.com/ They have a flash object that autoplays, and you can click on one of the buttons, but you never get the “click to activate” or the annoying outline around the object.
    Is there a code trick to fix this?
    Curtis Thompson replied 20 years ago 2 Members · 3 Replies
