Activity › Forums › Adobe After Effects Expressions › CLI Afterfx.exe -noui fails with Prototype Functions
  • CLI Afterfx.exe -noui fails with Prototype Functions
    Posted by Tomas Bumbulevičius on April 16, 2021 at 2:38 pm
    Hello guys, long time no see!
    I wonder did any of you experienced such issue, that running a script from CLI fails due to missing prototype functions? “isArray” or “indexOf” simply fails, while with UI it works as expected. Thus, my guess is that somehow its related with that UI can offer (maybe these libraries are embedded during GUI load)
    ERROR:
    ReferenceError: Function Array.isArray
    In case you have any workarounds in mind – I would be happy to check them, as for now the only option I see is pre-defining those functions in the scripts – which I would be more than welcome to not do…
    Cheers!
    Respectfully,
    Tomas
    Tomas Bumbulevičius replied 5 years, 5 months ago 2 Members · 3 Replies
  • Chris Voelz
    April 16, 2021 at 3:46 pm
    Which version of AE are you using?
  • Tomas Bumbulevičius
    April 16, 2021 at 5:47 pm
    Hey Chris, yes, sorry for not pointing out this. CC 2020
    April 25, 2021 at 11:30 am
    POTENTIAL SOLUTION:
    In case if someone runs into the same issue, try to include files from this (or similar) location on your machine:
    C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_12_165-1\jsx
