Activity Forums Apple Final Cut Pro Legacy Clearing P2 import window
  • Clearing P2 import window
    Posted by Scott Davis on January 14, 2008 at 5:23 pm
    This is my first time using the P2 import. How do you clear clips out of the window. I have a lot of clips I need to import and it is getting confusing as to what I have imported and what I haven’t
    Running:
    FCP 5.14
    Thom Obarski replied 18 years, 7 months ago 2 Members · 3 Replies
  • Thom Obarski
    January 14, 2008 at 6:55 pm
    When you have finished an entire “reel” (card) there’s a little eject button at the upper left hand side of the import window which will clear out all clips (whether rendered or not) that are associated with that reel from the import dialogue window.
    Hope that helped!
    ~Thom
    “This is post, you can’t fix it after this.”
  • Scott Davis
    January 14, 2008 at 8:48 pm
    Ahhh, thanks Thom.
  • Thom Obarski
    January 15, 2008 at 1:10 am
    NP good luck with your project!
    ~T
