Activity › Forums › Apple Final Cut Pro Legacy › Clear-up regarding image import in fcp
  • Clear-up regarding image import in fcp
    Posted by Lasse Laursen on July 31, 2009 at 6:27 pm
    I usually import all my still-images as jpeg, RGB 1998, baseline.
    I am working on a HDV sequence (1920x1080i).
    It looks okay, but the is this the right format to be workning in a HDV workflow – maybe I should import progressive instead of baseline?
    So I guess just a quick clear-up from a clever mind, can answer my question.
    /Lasse
    Chris Borjis replied 17 years, 1 month ago 2 Members · 1 Reply
  • Chris Borjis
    July 31, 2009 at 10:54 pm
    baseline/progressive is how jpegs get loaded on web pages.
    baseline = image loads after it fully downloads
    progressive = image loads looking pixellated then clears up after it fully downloads.
    it should have no bearing at all in fcp which you choose, but I usually do baseline
    to keep it simple.
