Activity Forums Maxon Cinema 4D Clear Plastic texture
  • Clear Plastic texture
    Posted by Stu Pond on July 24, 2007 at 5:46 pm
    I’m doing a model which has clear plastic components. I’ve been trying to get the texture right and struggling when I noticed the original plastic itself distorts everything behind it so it runs the length of the component – sort of streaks of light representing the light coming through the plastic itself. I guess this is a result of the manufacturing process.
    The light passing through the plastic is often split into a spectrum (like a rainbow) around the edges rather than white.
    Any tips if I am creating this using a texture?
    Cheers
    stigWeard
    Stu Pond replied 19 years, 1 month ago 2 Members · 4 Replies
  • Adam Trachtenberg
    July 27, 2007 at 12:08 am
    The distortion you’re describing sounds like like an anisotropic effect, which is caused by parallel scratches in a surface — like brushed steel. But I’m not exactly sure what you mean. Can you post a pic?
  • Stu Pond
    July 27, 2007 at 2:12 pm
    I can’t post a pic due to a confidentiality agreement.
    I’m struggling to sort this one, and am having all sorts of trouble with the illumination etc.
    I think I can emulate the surface properties using an environment map, but the transparency is behaving very oddly – there is a tube in the middle of the plastic barrel that has a graphic on – appears black every time, whatever I do.
    Thanks for the reply though!
    stigWeard
  • Adam Trachtenberg
    July 28, 2007 at 4:51 pm
    Hmm, maybe you need to increase the ray depth and/or reflection depth in your render options?
  • Stu Pond
    July 30, 2007 at 12:52 pm
    I’ll give that a go – cheers.
