Activity › Forums › Apple Final Cut Pro Legacy › Cleanup of “hollow’ or echo’ sound in a room
Posted by Al Bergstein on May 24, 2010 at 10:42 pmI had to shoot an interview in a room that was big, empty and had lots of hard surfaces. Despite best intentions it still has too much hollow or echo to it. Which audio filter would work best to minimize this sound?
Alf
Joel Moore replied 16 years, 3 months ago 4 Members · 3 Replies -
John Fishback
May 25, 2010 at 2:27 pmNot much you can do. Reflections/echo are very complex signals. My only suggestions are try some + or – eq around the reflection frequency range. And, sometimes taking away in the low hundreds of Hz can help. Second thought is to float in some masking SFX under the dialogue.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Mark Suszko
May 25, 2010 at 4:42 pmThe best plug-in for this would be Ben Burrt’s phone number:-)
on the theory that the reverb is slightly less energetic than the original sound, maybe some eq with downeard expanson would kill off more of the reverbed sound than the original sound? Just grasping at straws here. You’ve tried Sound Soap or something like that already, right?
Joel Moore
June 2, 2010 at 8:21 amI use Logic for all my audio. I have not used any of the FCP filters.
For audio editing one really needs to start with good quality reference monitors and a/d/a converters so they can actually hear what’s there before much time is spent working on it. Also a conservative amount of EQ can make a world of difference.
If you’re limited to the native filters, I would suggest trying any one or a combination of the 3-Band EQ, the expander/noise gate and/or the low-pass(aka treble-cut).
Hope this helps.
“Patience Luke, let the object of your desire come to you” — Obi-Wan Kenobi
