Activity Forums VEGAS Pro Cleaning Up Water Spots on Video
  • Cleaning Up Water Spots on Video
    Posted by Terry Fein on July 16, 2012 at 7:57 pm
    I was recently in Iceland, and shot a lot of video. The video in one location clearly shows water spots on the lens. See below:
    https://vimeo.com/45798626
    Is there any fairly easy and effective way in Vegas Pro to eliminate (at least minimize) the appearance of these spots? I also have some other video with a few far less visible spots (probably from dust on the sensor.
    Terry
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Terry Fein replied 14 years, 2 months ago 2 Members · 2 Replies
  • John Bolton
    July 17, 2012 at 3:02 pm
    Hello Terry. I guess the other experts will also offer you a solution but when I had the same problem that way I minimised it was by duplication the track so you then have two tracks. Go to the frame on the Upper track to where the problem blobs starts and Slice it and remove all of the part before that section and then go to the end of the problem bit and remove all of the bits after that. So you may have three or four small sections on the top track.
    So you are now left with a complete second track and a top track when the problem area is directly over the in sync with the second track.
    The on the Top track, using the Pan/Crop I masked out a very small section of ( in your case Sky ) just to either the left or right of the problem area depending on which area it like the area with the problem.
    The using the Feather with the mask tools just feather the edge to is it not sharp. Then I moved the top track using the Track motion so that the masked cloud nice bit on the top track covers over the blobs on the second track.
    As both tracks are in sync then the mask will always cover the blobs. Of course you will get some part where you will have to do a different mask area like when the blob goes from sky to another different area like rock.
    Whilst this is not exact science for me I got away with it..
    I also hope others will help you with some ideas
  • Terry Fein
    July 17, 2012 at 5:50 pm
    Thanks. I’ll give it a whirl. I’m got some other footage that is less complicated to clean up (basically just one spot in the middle of a large body of water), so I’ll try it on that first.
