Cleaning up “fast moving” video
Posted by Charity Meinhart on December 8, 2011 at 11:42 pmHey guys! I have no idea of the terminology for this, but I shot some action video (ATVs) with my Canon 7D and it comes across with those kinda choppy, vertical lines like the picture can’t keep up with the video… it also happens when I pan too fast… does that make sense? If so, what is that called? I’m trying to fix it in Sony Vegas, but don’t really know where to start. I’m also testing out the Boris effects, if that might help… Any thoughts?
Thanks!!!
~Charity
Everywhere I go, there I am.
Charity Meinhart replied 14 years, 9 months ago 3 Members · 8 Replies -
Nigel O’neill
December 9, 2011 at 3:03 amIn your project properties, set the deinterlace method to blend. Render your output and see if the problem remains.
My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Ron Bakker
December 9, 2011 at 3:48 amAre we taliking about the jelly effect, I don’t think SV stabilizer would fix this but I’m pretty sure there is a plug in from boris or some one that can fix this.
Pentium 2.4 quad|Asus P5G41C-M LX mobo|4 gig corsairs 6400 ram|Corsairs 630 power supply|Gigabyte 8800gt|2x seagate 500gig Hd’s|Lg dvd burner|windows7 premium , SV9E
Ron Bakker
December 9, 2011 at 4:41 amWait sv 10 and 11 have rolling shutter correction…Cool.
Charity Meinhart
December 9, 2011 at 5:54 am“Deinterlace!!! That’s the word I was looking for! I’ll give it a shot… thanks for the tip!
Ron Bakker
December 9, 2011 at 6:21 amBut isn’t 7d footage progressive?
Charity Meinhart
December 9, 2011 at 11:50 pmHow do you use the rolling shutter correction? Also- when I’m shooting sports should I be set to 30 frames or 60?
Ron Bakker
December 10, 2011 at 12:50 amI think it’s pretty easy to use.
Here is a you tube video showing the stabilizer plug in being used and you can see a tick box for the rolling shutter correction.
You can use 30 frames per second, but depending on how fast the action is maybe have the shutter speed between 100th or 200th of a second. 60fps is good if you intend on slowing it down later but it will only be 720p if your shooting with a 7d.
https://www.youtube.com/watch?v=kKJgZ7_9vTUPentium 2.4 quad|Asus P5G41C-M LX mobo|4 gig corsairs 6400 ram|Corsairs 630 power supply|Gigabyte 8800gt|2x seagate 500gig Hd’s|Lg dvd burner|windows7 premium , SV9E
