Activity Forums Adobe Audition Cleaning pops caused by a faulty lead
  • Cleaning pops caused by a faulty lead
    Posted by Markhp on May 22, 2006 at 3:04 pm
    I have a live recording of a classical concert recorded in a church with quite a resonant acoustic. During two of the pieces, a keyboard was used. Unfortunately this had a faulty lead, with the result that there are some very hefty pops that I’m trying desparately to fully eliminate. What is the best way to deal with these? The click/pop eliminator doesn’t do the trick, presumably because they’re either too loud or at a different frequency?
    Any help would be much appreciated.
    Mark Hartt-Palmer
    Willie Toth replied 20 years, 3 months ago 2 Members · 3 Replies
  • Willie Toth
    May 22, 2006 at 3:56 pm
    Did you try to remove using the spectral mode? You can only remove one pop at a time but it works very well … Read the help file on “Single Pop Removal” … If you are still having a problem E-mail me a minute are so to loganonestudio@aol.com and I will see if I can help … WILLIE
  • Markhp
    May 22, 2006 at 4:04 pm
    Yes, I did try this. I think the problem is that because of the echo, the Repair Transients is not possible because the selection is too big.
    That’s really kind of you. I’ll give it another go, but if I still don’t get anywhere then I’ll most probably take you up on your generous offer.
    Mark Hartt-Palmer
  • Willie Toth
    May 22, 2006 at 5:44 pm
    Mark,
    No problem, glad I can be of service ……… WILLIE
