Activity › Forums › Adobe Premiere Pro › Cleaning out files from the startup or scratch disk?
  • Cleaning out files from the startup or scratch disk?
    Posted by Nelson May on December 8, 2008 at 6:41 pm
    I am an FCP user, but use Premier Cs3 at Work. I was told that had a default folder for a scratch disk. You have to set them up in FCP. anyway, the main HD on the MAC is full and I need to clean out some files so CS3 can run. The other items of the adobe suite say the disk is full.
    Where is the folder so I can get in a clean out the files on the scratch disl. This particular machine has 10.5.5.
    Thanks in advance
    G5, 1.7, 4MB RAM, 30″cine, G4, 1.6 2MB RAM, Mbox, Neumann TLM-103, FCP HD 5. Pro Tools, Adobe Creative Suite, Reason 3.0, Macromedia Studio, ProAnimator, HVX200 with Firestore v4.0
    Hector Melendez replied 17 years, 9 months ago 2 Members · 1 Reply
  • Hector Melendez
    December 9, 2008 at 2:45 pm
    Simulated as you’re going to start a new project and it will lead you to find where are you storing in the window show up (When it ask you to where to save the raw, look what drive and folder, go there and erase all old projects)
    (Dont know if its clear to you)
