Activity › Forums › Panasonic Cameras › Cleaning MiniDV Tapes?
Posted by Accountneedsrealnameupdateorgoodbye on February 11, 2007 at 7:26 pmDoes anyone know how to clean them? One of mine in the beginning of some footage I filmed has green bars across the screen and once in a while something on my camera will pop up during then, saying tape needs cleaning.
Herb Fellows replied 18 years, 3 months ago 4 Members · 5 Replies -
Noah Kadner
February 12, 2007 at 7:48 amYou don’t clean tapes, you clean the tape heads of your deck or camera with a head cleaner which you can buy. If that doesn’t work you need to have the heads cleaned professionally at a camera repair center.
Noah
Unlock the secrets of the DVX100 and Final Cut Pro!
https://www.callboxlive.com -
February 13, 2007 at 9:03 pmThe specific tape gets the same reaction on any camera I play it on. All of my other tapes are fine on any camera.
Noah Kadner
February 15, 2007 at 7:27 pmThen it’s possible the tape was recorded with dirty tape heads. In that case take the tape to a professional post-production place- they might be able to save your footage and dub it onto a clear tape. There’s no way to clean tapes.
Noah
Steve Wargo
February 19, 2007 at 7:20 amFind someone with a Sony DSR2000 tape deck. It has a special circuitry that will play tapes that no other deck will play. Few people know about this but it is the coolest thing that Sony has ever done. There is a special playback mode to accomplish this.
Steve Wargo
Tempe, ArizonaIt’s a dry heat!
Herb Fellows
June 23, 2008 at 3:31 pmI have a sony camcorder, trv-19. It plays and records on new tapes without a problem. However, on some old tapes, it will only play. I get the ‘dirty tape’ mmessage when I try to record.
First, if the tape is dirty, why would it play but not record? Dirty is dirty, no matter what you’re trying to do, right?
These ‘problem’ tapes are under 3 years old, and have only been recorded on once. If I knew these tapes were essntially disposable, I would not have bought this format for a camcorder, this can get really expensive. I have one $15 sony memory tape, used once, now reads ‘dirty tape’. That really sucks!
