Activity Forums Adobe Premiere Pro Cleaning Audio
  • Cleaning Audio
    Posted by Steve Adams on November 6, 2018 at 11:27 pm
    I created some tutorial videos with Camtasia a while ago and used Audacity to remove some background noise from the audio track. I broke out the audio to a separate file and gave it to Audacity. First Audacity wanted a few seconds of just the noise and then it went back through the entire soundtrack and subtracted that noise. The result seemed miraculous! The background noise was totally gone. I’d like to do that now with a video i’m editing with Premier Pro CC2017. Has anyone had experience doing this? Is it possible from within PP? Maybe someone could point me to a tutorial.?
    Thanks for any help.
    Steve Adams replied 7 years, 9 months ago 2 Members · 3 Replies
  • Steve Adams
    November 7, 2018 at 6:12 am
    Thanks. What about breaking the Premier Pro audio track out to a separate file, removing the noise in Audacity as above, and then putting the clean audio back into the Premier Pro clip?
  • Greg Janza
    November 7, 2018 at 4:41 pm
    You also can purchase a plugin that will do it very well with little effort in Premiere:
    https://accusonus.com
    Windows 10 Pro | i7-5820k CPU | 64 gigs RAM | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
    Adobe CC 2019 13.0 | Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 x 2 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with Resilio
  • Steve Adams
    November 7, 2018 at 9:13 pm
    After a bit of research I see it’s easy to export the Premier Pro audio to a file and then import a new audio file for the clip. So that’s the plan, using Audacity to take out the noise.
    Thanks for the inputs
