Activity Forums Adobe After Effects cleaning and retouching complex shot
  • cleaning and retouching complex shot
    Posted by Chris Ten on June 15, 2012 at 7:43 am
    Hello
    I have the job to clean close-up shots of luxury watches. I have to remove dusts, scratches and fingerprints.
    So far so good. But there are some shots which are a bit complicated to handle with the clone tool.
    For exemple this shot:
    https://www.youtube.com/watch?v=3R9llAD9C_M
    The dust between the hand of the watch and the screen is full of small bright dust. When i use the clone tool it looks great on each frame but when i play the video you can clearly see it has been “worked on”.
    Is there any technique or advice you could share on this matter? That would be great because i have no clue how to make it look perfect.
    Thanks for your help
    Chris Ten replied 14 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
