Activity › Forums › Apple Final Cut Pro Legacy › Cleaner XL FCP codecs
Posted by Tom Amici on February 10, 2009 at 4:12 pmCleaner XL will not recognize FCP QuickTimes. Is there anywhere I can download a codec for this?
Thanks.
-Matt
Tom Amici replied 17 years, 7 months ago 3 Members · 7 Replies -
Daniel Low
February 10, 2009 at 5:13 pmWhat FCP codec are you using? There are very many.
Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free! -
David Bogie
February 10, 2009 at 6:31 pmCleaner XL is a windows application. You must have QT installed on the PC.
bogiesan
Daniel Low
February 10, 2009 at 6:42 pmCleaner XL installs Quicktime or requires it to be installed as part of its installation process and I believe will throw an error if later remove QT.
I know plenty of people who have this type of workflow (cheap PCs as encoding farms) but they use cross platform QT codecs, which is what I was getting at here.
Tom Amici
February 10, 2009 at 6:57 pmI do have Quicktime installed. I can process most files, but sometimes I only get the audio, meaning I am missing a codec, I assume. I guess I would have to look at the files on a case by case basis. I usually ask for uncompressed to be safe, but sometimes I have clients who need a quick turnaround and their system crashes on them. In these cases, I bring them into Compressor, but I don’t want to use Final Cut as a cruncher while there is work to be done.
-Matt
Tom Amici
February 10, 2009 at 7:13 pmCleaner will recognize “Apple ProRes 422 (HQ), 1920X1080, Millions”, but not “Apple ProRes 422 (HQ), 1280X720, Millions”. From what I can see, this is the only difference between these files.
-Matt
David Bogie
February 10, 2009 at 11:56 pmDan, sorry, I wasn’t addressing you directly, didn’t notice the indent on the thread till after I posted.
The OP:
[Matt Press] “Cleaner XL will not recognize FCP QuickTimes. Is there anywhere I can download a codec for this?
Thanks. -Matt”Who knows where to start on THAT question?
There are a bunch of codecs that you only get with FCP6 and possibly QT Pro. The PC will not have access to them unless the recent QT7.6 update includes some way to see them. I doubt it, too Apple-specific. Mostly, you export from FCP to the best codec your CleanerXL will recognize, least common denominator.
bogiesan
Tom Amici
February 11, 2009 at 3:52 pmThat makes sense. I tell clients to send me proper files, but they get lazy or rushed. I’ll just keep QT updated and jump on Compressor if necessary.
-Matt
