Activity Forums Compression Techniques Cleaner MPEG 1 scrubbing problem
  • Cleaner MPEG 1 scrubbing problem
    Posted by Charlie Seetoh on November 15, 2005 at 8:57 am
    Hi all,
    I’m having problem in scrubbing through MPEG 1 files encoded from Cleaner 6.0.
    The clips playback well if you play it from the beginning of the clip but if I were to scrubb forward or backward, the clip will not play at all. I have try playing and scrubbing through quicktime 6 player and VLC. However, I noticed that if I did not choose mutiplex during the encoding process, everything is perfect, scrubbing is very smooth. Unfortunately, my requirement is to have a multiplex file. BTW, I have try encoding MPEG 1 using ffmpegx and I don’t seem to encounter such scrubbing problem.
    Any help is much appreciated.
    Charles Simonson replied 20 years, 10 months ago 2 Members · 1 Reply
  • Charles Simonson
    November 16, 2005 at 1:17 am
    Yes, the scrubbing issue with Cleaner 6 encoded files is a known problem, and probably one that will never be fixed. You pretty much hit the nail on the head where the issues lies in the muxing.
