Cleaner 6.5 and error code – 47
Using a Dual 2.5 and OS X 10.4.6 and recently upgraded cleaner to 6.5. I get the following in the batch log…
ERROR at 3:29:41 PM: An error occurred while exporting the file (QuickTime Export error). (File busy (ID= -47))
3:29:41 PM: Analysis aborted.
ERROR at 3:29:41 PM: Unable to use QuickTime export. (File busy (ID= -47))I am creating 3 alternate files and usually get 2 compressed and one fails. All the files a created in FCP, saved in the same manner. This does not happen with all files. I can put 6 files in a batch and 1 or 2 will fail.
Any ideas will be appreciated. I cannot find anything that tells me what a -47 error is.
