Activity Forums Adobe After Effects Clean plate jumps when put into 3D?
  • Clean plate jumps when put into 3D?
    Posted by Justin Crowell on November 23, 2016 at 12:46 am
    Hi all,
    I know I’ve solved this problem in the past, but can’t figure it out now.
    1) I use the camera tracker on my video.
    2) I build a clean play for a neutral frame in the middle of the video, using Photoshop.
    3) I put that layer on my timeline at the right frame. It matches.
    4) I create a null and camera based off the track points in the area I want to replace.
    5) I flick my clean plate into 3D, and…it jumps. It’s offset in 3D space now.
    Image and video are same frame size. I’m confused.
    Editor, Motion Graphics Designer, Director
    JustinCrowell.com
    Greg Gesch replied 9 years, 10 months ago 2 Members · 1 Reply
  • Greg Gesch
    November 23, 2016 at 1:58 am
    Hi Justin, I would suggest adding a solid rather than null and resize/rotate as necessary to cover the area. Then double check that it is sticking. If so, copy its coordinates (including rotation if applicable) to your clean plate. Does that help?
