Activity Forums Adobe After Effects Expressions Clamping x position on after effects
  • Clamping x position on after effects
    Posted by Gabriel Rocha on October 8, 2012 at 8:42 pm
    hello,
    Is there a way to clamp a X Position opn after effects on several different values?
    I’ve been using this code:
    x1=1024.3322
    x2=1224.1572
    clamp(transform.xPosition,x1,x2)
    if (transform.xPosition>x1) {
    transform.xPosition=x2;
    But that only allows me to snap from one position to another. I’d like to be able to snap into 6 positions (on X dimension).
    is there a way to do that?
    I use the Snaped position to get the position value and use in another layer but i really need to be clamped.
    GR
    Meng Zhang replied 9 years, 5 months ago 3 Members · 13 Replies
  • 13 Replies
  • Dan Ebberts
    October 8, 2012 at 8:56 pm
    Something like this should work:
    xVals = [1024,1224,1444,1624,1824,2024];
    i = 0;
    while (value > xVals[i] && i < (xVals.length-1)) i++;
    xVals[i]
    Dan
  • Gabriel Rocha
    October 9, 2012 at 12:54 pm
    Hey Dan,
    I knew you would come for the Help.
    Right now for some reason it’s not working.
    im not sure if i made myself 100% clear.
    Check the file i uploaded as an example of what i have now. Just slide the layer to On and OFF.
    Download the AEP here:
    https://www.sendspace.com/file/gjj1pi
    But instead of ON and OFF i would have Value 1, Value, 2 Value 3, Value 4…
    Im adding your code on the xPosition but i get the Layer stuck in one single position.
    Thanks again for your help!
    http://www.gabrielrocha.com
  • Gabriel Rocha
    October 9, 2012 at 12:57 pm
    ok forget about it.
    The code you sent wasn’t working on my original Project, but its working on a plain project (like the one i uploaded). SO it must be something on my previous project.
    I’ll check it out! Thanks man. You rock!
  • Gabriel Rocha
    October 10, 2012 at 8:23 pm
    Hey Dan,
    What if i want to slide a layer on the xPosition, but having a limitation.
    Let`s say i want to slide it from 1024 to 1530, not clamping just being able to slide from 1024 to 1530, limiting the beginning and the end to those values?
    I`ve found similar possibilities, but none quite the same here on CC.
    THanks again in advance,
    GR
  • Dan Ebberts
    October 10, 2012 at 8:36 pm
    Are you talking about something different than just right-clicking on the slider value in the Effect Controls window and setting the slider range?
    Dan
  • Gabriel Rocha
    October 10, 2012 at 8:42 pm
    Yes, i want to do that on the Viewport.
    I know about the slider, checkbox and stuff on the Effects tab, but i want to do that on the viewport. you know what i mean?
  • Dan Ebberts
    October 10, 2012 at 8:57 pm
    Sorry, I’m not sure. By “Viewport” do you mean the Comp window?
    If you’re talking about an expression that would keep you from dragging a layer outside that range, that be a clamping expression for X Position like this:
    clamp(value,1024,1530)
    If not, I’m not sure what you’re trying to do.
    Dan
  • Gabriel Rocha
    October 10, 2012 at 9:01 pm
    Actually that’s perfect.
    I didn’t know Clampping would give me that result.
    I thought that clamping would be more like snapping.
    THanks again man, that helped!
  • Meng Zhang
    April 10, 2017 at 5:10 pm
    That’s awesome. Does anyone know how can I limit the position within a polygon, like a mask or shape layer? I have been searching for this, but no luck. Thanks guys!
  • Dan Ebberts
    April 10, 2017 at 8:17 pm
    I don’t think there’s a practical way to do that. You could hack something together with sampleImage() on a shape layer, but it would be quite a bit of work to get it set up.
    Dan
